Hours Run Meter?
Discussion in 'Plasma TVs Forum' started by midniteman, Apr 5, 2003.
  1. midniteman
    midniteman
    Hi all,
    Can somebody please tell me how to check the 'hours run' meter I keep hearing about..?
    I have the 5 series 50" Panasonic and am curious about knowing if this screen realy is brand new or if it's been used as a display (I know I'm an untrusting so and so aren't I??!!).
    Is this function a myth or does it really exist as I can't find anything about it in the manual...?!
    Thank you very much in advance!
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Originally printed by jmack
    "Hold the volume button on the panel in while pressing the button under the power button (the status button) 3 times very fast.
    ** status button is the one on the remote under power on/off **
    Highlight the sd mode, then select. It tells you how many times you have powerd on and off the panel and even better an hour meter. I think the hours are on the right PT and the on/off meter WT is on the left .
    I dont know what the rest of the stuff is.
    PLEASE BE CARFULL IN THERE
    sorry lynx"
  3. midniteman
    midniteman
    Thanks for taking the time to reply...
    Could somebody please tell me if the hours run (PT - I think?) is actually in hours or in minutes?
    Mine says PT = 180, so is that 180minutes or 180hours?
    Thank you!!!
  4. jmack
    jmack
    its in hours and the wt is how many times its been powered up
    be carefull in there ok
  5. midniteman
    midniteman
    Hmmm... That sounds a bit suspect?
    A brand new Plasma (supposedly) with 180 hours (PT) showing on the meter!
    I think I'd better give the shop a call as it sounds a lot like a reconditioned jobbie!!! :(
  6. jmack
    jmack
    i know a few people on here have had different amount of hours on theres when new as they must run some tests or quality control. yours might be the one picked out for quality testing, if you have no buzzing and all your pixels are in tact then i would leave it knowing (or thinking ) atleast mine has been tested properly, enjoy it as its barely broken in
  7. midniteman
    midniteman
    Thanks jmack, isn't 180 hours a little extreme for quality testing though?
    If you guys think I should leave alone I guess I will... But does anyone think it's an reasonable amount of hours for a brand new display?
  8. jmack
    jmack
    if it helps mine is on 800 hours and the picture quality is much better now than the first few hundread hours , it seems to settle down after a bit
  9. YYZ
    YYZ
    Anyone know if the Fujitsu PDS4229 has a similar hours meter feature hiding away somewhere?
  10. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Why ? :confused:
  11. jmack
    jmack
    i think he was quoting me from a while back when you told us off for pm the codes instead of just posting them
  12. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    I copied jmack's previous post & didn't edit that out :suicide:
    Oh I see jmack has already answered that now.....quicker than I can type :suicide: :smoke:
  13. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    You make me sound like an old school master.
  14. jmack
    jmack
    yes sir
