Hours on Plasma
Discussion in 'Plasma TVs Forum' started by cheeseburger, Dec 27, 2003.
  1. cheeseburger
    cheeseburger
    :clap: Hello people.
    Can anybody tell me how to access the counter on a Panasonic 37PW5 to find out the hours that it has run for.
    Many thanks. Burger.
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Originally printed by jmack
    "Hold the volume button on the panel in while pressing the button under the power button (the status button) 3 times very fast.
    ** status button is the one on the remote under power on/off **
    Highlight the sd mode, then select. It tells you how many times you have powerd on and off the panel and even better an hour meter. I think the hours are on the right PT and the on/off meter WT is on the left .
    I dont know what the rest of the stuff is.
    PLEASE BE CARFULL IN THERE
  3. wattsj
    wattsj
    Is this the same for the PW6 ?
    And how do you exit without doing any damage ?
  4. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    Can these plasmas be 'clocked' in a similar way to cars.
    And is this a problem when looking for secondhand plasmas?
  5. cheeseburger
    cheeseburger
    :clap: Thanks Vonhosen.
