hotbird3 sat location?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by asa_5, Aug 20, 2005.
  1. asa_5
    asa_5
    hi
    my mini dish is set up on astra 2 sat i would like to view a channel from hotbird3 sat is the location of hotbird3 sat deferent from astra 2 if yes how much in which direction?
    thanks
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Hotbird 3 is at 13 degrees east of south, which means that your dish needs to be pointed 15 degrees west of where it is now (and the azimuth adjusted to suit).
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,269
    Manchester
    +758
    I think Nick meant "elevation" adjusted to suit.
    Basically to point at the 13 degree east geostationary orbital slot your dish will also need to point a couple of degrees higher.
    Chris Muriel, Manchester
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Yeah, sorry - a "senior moment" crept in :)
  5. asa_5
    asa_5
    I am a bit new to sat and degree stuff, will that be OK, if i turn the dish a bit to the West from where it is now in Astra 2 (about 3 centimeter?) and a bit higher.
    Will i be able to to view the current channels? e.g. bbc3 reality tv etc..
    thanks
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You can only watch one satellite at a time. If you want to watch a second satellite, you will need either a second dish, or a means of moving your existing dish accurately between the two satellite positions. Bear in mind that if you are using a Sky box, you will have to tune in extra channels manually, and the settings available for symbol rate and FEC are not as varied as those available with non-Sky digital boxes, so you may not be able to tune the channel.
  7. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,269
    Manchester
    +758
    Nick is correct.
    $ky digiboxes are deliberately nobbled such that they will only accept signals from multiplexes with symbol rates of either 27500 or 22000 (KSPS) .
    Chris Muriel, Manchester.
