Hotbird & Astra
Discussion in 'Satellite TV, Sky TV & FreeSat' started by asa_5, Aug 29, 2005.
  1. asa_5
    asa_5
    i heard there is a way to watch channels from hotbird and astra with one minidish in the uk.
    My question is? Is it easy to do this? I am a newbie and only managed to fix the dish on Hotbird.
    Is there a guide to install extra lnb on the manidish? Or does is it need specialist equipments and knowledge.
    Second question
    at the moment i can only view Horizontal (H) channel. Why cant i view Vertical channels?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You need to give more information.
    What satellite receiver are you using, and what size dish, and where are you in Europe ? Do you want to watch Astra at 19.2E or 28.2E ?
    The short answer is that a twin-LNB arrangement won't work with a mini-dish if you want to watch Astra at 28.2E (which is where Sky digital is). You will need a much bigger dish, or some way of steering a single dish (like a motorised dish mount).
  3. asa_5
    asa_5
    I am in the North East of England. I use a Panasonic d??30 and the dish is a mini one.
    Do you think I should get an extra channel? my other question was "why i cannt view vertical channels.
    thanks
