Hot Transformer
Discussion in 'Smart Home, Climate Control & Security Forum' started by tylandr, Apr 5, 2005.
  1. tylandr
    tylandr
    I have installed a ceiling light in the kitchen that has (6) 50w halogen bulbs. All are attached to a flexible rail that is suspended from ceiling using 6-inch standoffs. The problem is that after the lights were on for awhile, the base holding the transformer was warm to the touch, but not warm enough to burn. However, the shaft coming out of the base that the rail actually connects to (and transfers the power) was hot enough to make you think you were blistered.
    Now, the lights do not work at all. I know the house wiring ( (2) 12 gauge w/ground) is ok because the flourescent light that was there worked for 20 years. It just fell out of favor with my wife :thumbsdow
    Any suggestions?
    Thanks.
  2. Snow Board
    Snow Board
    You say you know the house wiring, what do you mean by 12 gauge etc etc, is this the Low voltage wiring you refer to, ie. what the lights are mounted to?
  3. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    I think this guy is American, Snow Board - Tylander sounds like you had a faulty connection between the transformer and the track which has now burnt right out, get a new fitting.
  4. tylandr
    tylandr
    I'll give that a shot. By the way, I am an American - just not too proud of it. I guess you guys are mostly Brits?
    Don't Blame Me - I Didn't Vote For Bush
