Hot-Link ir extender, usable with Sky+?
Discussion in 'Sky Digital TV Forum' started by spook, Dec 7, 2004.
  1. spook
    spook
    May 18, 2004
    157
    Hi all, I'm looking for an ir extender system so that i can hide my gear out of sight, bit confused with this one:
    Hot Link click here
    they seem to be under the impression that it won't work with Sky+?
    the only reason I can think of, is that they think that the Sky+ remote uses IRDA commands, now I know this can't be true as I use a Harmony655 universal remote with my Sky+ box and it works just fine (the H655 can't produce IRDA signals)
    so my question is, are any of you guys using a hotlink with Sky+?
    cheers, Spook
  2. pezzer
    pezzer
    Jun 9, 2004
    185
    West Sussex
  3. pezzer
    pezzer
    Jun 9, 2004
    185
    West Sussex
    sorry thought you were looking at sky link set up - satcure might still help !
  4. Scrappy Doo
    Scrappy Doo
    Oct 22, 2004
    HI,
    I use the Powermid Plus system with a Sky+ Remote upstairs and this works ok and controls everything downstairs.
    I would assume that this will work in the same way (ie. RF signals)?
    Cheers,
    Scrappy Doo
  5. varkanoid
    varkanoid
    Jan 6, 2006
    397
    +40
    whats the Sky+ code for the Powermid Plus ?
