Hot-Link ir extender, usable or not with Sky+?
Discussion in 'Home Cinema Control & Remote Controls' started by spook, Dec 7, 2004.
  1. spook
    spook
    May 18, 2004
    157
    Hi all, I'm looking for an ir extender system so Tthat i can hide my gear out of sight, bit confused with this one:
    Hot Link click here
    they seem to be under the impression that it won't work with Sky+?
    the only reason I can think of, is that they think that the Sky+ remote uses IRDA commands, now I know this can't be true as I use a Harmony655 with my Sky+ box and it works just fine (the H655 can't produce IRDA signals)
    so my question is, are any of you guys using a hotlink with Sky+?
    cheers, Spook
  2. Tyke
    Tyke
    I don't have a hotlink, but using a cheap and nasty RF signal and IR remote device to punt my Sky signal to another floor works a treat with the signal and remote commands. Since the hotlink looks a decent bit of gear I would expect it stands a fair chance of coping.
