Hot LCD ?
travid
I have just bought a Samsung 26" from Pixmania.
I understood about the 2 pin plug and bought a 13 amp adapter ie 2 pin to 3 pin.
OK, but the tv seems to get quite hot (wife discribed it as b.... hot), with a lot of heat comming from the back (yes I know its supposed to:rolleyes: ) and from the screen.
Is this nomal "new LCD" behaviour or something I should be worried about ?
I bought this with the understanding that no type of transformer was required.
Any help/advice greatly appreciated
TA
MattZani
LCD's in shops get hot, but my Bravia 40" only gets warm (it has a fan, not sure if all TV's do) and one's in my local hi-fi shop only get warm.
Don't know if over voltaging it would make it get hotter, and whether thats what you're doing.
travid
Thanks for those 2.
I dont believe I am over volting the set, however if any body has bought a set this way (via a euro supplier) I would be interested in your opinion.
As an edit, the tv has no problems with circulation
Pantera6
unless you see flames one day mate i think youll be fine :) .
you might also find where it is hot is the air vent where all the hot air is comming out from! because i know with mine i got little vents at the top and its not he plastic which is hot, just the air comming out...
