Hot Hot Hot
Discussion in 'Blu-ray & DVD Players & Recorders' started by DEANO65, Feb 19, 2003.
  1. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    IVE JUST BOUGHT A DENON 3800,BRILL PICTURE AND SOUND,ESPECIALLY WITH PAL PROG.BUT THE PLAYER RUNS VERY HOT AROUND THE TRAY AREA,I AM WORRIED, MY DVD,S ARE COMING OUT HOT, THIS HAPPENS ABOUT 45 MINS OR SO INTO THE MOVIES. CAN ANY ONE ADVISE ME THANKS:
  2. nathan_silly
    nathan_silly
    Is the Denon in a enclosed cabinet? Do you close the door?
    Have you left a gap above the DVD player? (at least 3")
  3. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    CHEERS FOR THE REPLY ,IT IS ON TOP OF A 3802 NOTHING ABOVE AND IS ON A AV RACK
  4. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    3800s do run hot anyway, but cooking it above your amp can't help. Feel the top of your receiver after 45 mins and you'll be surprised at how hot it gets..especially if you are playing the movie at any volume.
    Perhaps you could switch shelves to put the DVD beneath the 3802?
    Ian Guinan
  5. nathan_silly
    nathan_silly
    Move the DVD player away from the AV amp, put the DVD player onto a seperate shelf.
    Nathan
  6. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    THANKS GUYS ILL GIVE ILL TRY YOUR SUGGESTIONS
  7. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    Some of the 3800's do run hot to start with, but from other reports, do tend to cool down once they have been run in for a while.
    Also check out http://www.avsforum.com/avs-vb/showthread.php?s=&postid=1869477&highlight=3800+hot#post1869477 for more info on 3800's runnning hot and problems with the US players
    The first three digits of the serial number will tell you the build date of the unit - the first digit is the year (i.e. 2 =2002) and the next two are the month (i.e. 11 = Nov) - so 212XXXXX would mean a Dec 02 manufactured player. As I remember, some of the older units did run hot and also had the potential to have problems with skipping and freezing on DVD's - newer builds seem much better in this respect
    Check out my site for other 3800 info inc. known issues...www.geocities.com/denon3800
    JJ
    P.S. Try not to use CAPS in your post as this makes it difficult to read and is often interperated at shouting...just a tip...:)
  8. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    AND ILL GET SOME SPELLING LESSONS
  9. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    thanks for the advice Jasonjo
  10. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    no probs...enjoy the player ;)
  11. ditton15
    ditton15
    Oct 20, 2002
    536
    16
    edinburgh
    difarant weighs off speling is apperantally Ok BUT USE OF UPPER CASE IS NOT RECOMMENDED. :p
    However, as it seems that you can spell, just ease off the shift key and you'll do just dandy. :D
    ditton
