hot fuzz combo won't play on my 360 hd 'help!'
Discussion in 'Xbox Forums' started by nlindenj, Jan 19, 2008.
  1. nlindenj
    nlindenj
    Dec 15, 2005
    168
    hi all
    i hope you guys can help, how do i get my hot fuzz combo hd dvd to play on my 360 hd dvd player
    i know that this 2.0.4641 is supposed to fix the problem but i can't find it anywhere to down load i have downloaded the dec 07 firmwear but still no joy
    please help:lease:
    thanks in advance
  2. thommcghome
    thommcghome
    Dec 29, 2006
    276
    +12
    2.0.4641 was the November HD DVD Player software update, December's release was 2.0.4645. So you already have the fix installed as a result.
    Bad HD DVD?
  3. nlindenj
    nlindenj
    Dec 15, 2005
    168
    not a bad hd dvd, a bad operater namely me (d'oh!) i didn't copy both files onto a rwcd i only copied one (what an idiot i am)
    put in the update and works perfectly:clap:
    thanks for your help
    could the mods close this thread, cheers
