Hot Amp!
Discussion in 'Home Cinema Speakers' started by lambpie, Mar 15, 2001.
  1. lambpie
    lambpie
    I have a Denon AVC A10SE amp and I am considering upgrading my speakers to a set of KEF TDM's with a 4 Ohmn Impedance. However, reading the Manual, Denon suggest that 6 - 16 Ohmn Speaker is attached.
    Will my Amp be able cope with these speakers??
    I am happy that it will, given that the speakers have a sensitivity of 90dB and I rarely have the volume at eardrum popping levels.
    If anybody disagrees or can suggest another Speaker package, let me know.
  2. mart.stokes
    mart.stokes
    I have spoken to Denon in the past at a show (where they were using KEF THXs at 4 ohm) about this very subject in reference to my AVC-A1D. Their answer was quite simple, they stated that there was nothing to worry about because (like yours) the amp meets THX standards. Makes their warnings on the casework a bit stupid then!
  3. Guest
    I had a similar question not long ago except I was driving the amp with higher-than-suggested-impedance speakers.
    From what I gathered, if you have lower than amp impedance then you'll be driving the amp much harder.
    Check this thread out:
    http://www.wvip.co.uk/ubb/Forum10/HTML/000301.html
    --BK
