Hot Amp?
Discussion in 'AV Receivers & Amplifiers' started by james4001, Jan 9, 2004.
  1. james4001
    james4001
    Dec 14, 2003
    43
    11
    Hi I have just bought myself a sony STR-DB790 reciever and wondered if i put my DVD player on top of it would it overheat? the DVD player doesnt cover the whole of the top of the reciever there is about a 1/3 of the ventalation not covered and about a 1cm gap between the reciever and player.
    Any comments would be appreciated
    James
  2. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    James,
    I wouldn't put your DVD player on top of the amp. The amp needs adequate ventilation (around 2" all round" and your DVD player could overheat, after all heat rises!
    Regards
    John
  3. Hawklord
    Hawklord
    Feb 15, 2003
    3,432
    Aldershot, Hampshire
    +260
    You can purchase risers though that'll increase the gap between them if you have the space.
  4. james4001
    james4001
    Dec 14, 2003
    43
    11
    Where could i purchase risers from?
    James
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    My "risers" are squash balls cut in half.
    Basically, it just needs to be something you can put under the corners of the DVD player to lift it up a bit. Offcuts of wood or anything like that would be fine.
  6. james4001
    james4001
    Dec 14, 2003
    43
    11
    Thanks for that advice, i think 2 squash balls cut in half wont break the bank. I might go with that or if i have enough time i will get some realy thick round wood, cut them to size and paint them silver so it fits in with the styling. My amp has nothing with in about 50cm around it apart from my DVD player on top wich only covers 2/3 so i think it will be fine now.
    James
