hosting live games
Discussion in 'General Video Gaming Chat' started by nojay, Nov 29, 2004.
  1. nojay
    nojay
    Having problems hosting private games on xbox live. Am ok hosting a quick game. Have had 10 people in with no problems. When I try to host a game for friends only, it only allows one to join.….others get game no longer available messages. I have set the games with enough friends slot etc. Is there any config I need to do in order to let friends in numbers?
  2. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    First of all what game are you having this problem with?
  3. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    What game you are trying to host would be a good start :). Are your Newtwork settings all open ?? To check this goto the connection screen on xbox dash and wait for it to connect and press Y it will list your NAT, MTU etc settings these should all be rated 1 - this means you are open and can have anyone join you on live.
    What broadband speed do you have?? as this may effect how many you can host - depending on the game.
  4. nojay
    nojay
    It happens with all games. My example was pgr2. I have no problems hosting public games with lots of players but cannot host a game with more than 1 friend..... I do not get any errors on screen but they get cannot connect message. I get the problem when trying to join them when they have set the game up.....I have 512 connection.
    The same happens with ghost recon and rainbow six 3
    Thanks for the reply and will check that my connections are all open
  5. meinbrain
    meinbrain
    i have this problem with PGR2 ALL the time. its a known flaw. prob not you! it can also be a prob if one of you/some of you didnt get the add on packs.
    its well annoying. i have never been able to play one of my mates. EVER!!!
