Horny Dragons Recomendation
Discussion in 'Plasma TVs' started by Bobby_Dazzler, Apr 24, 2005.
  1. Bobby_Dazzler
    Bobby_Dazzler
    Hi All
    I just want to thank HD for recomending a superb setup for under 2k.
    I have just plumbed in my PW7 with a JS Tech rgb to vga convertor and im sooooo impresed.
    Im in the middle of moving home so I havnt connected the vsx c502 or the CD1's yet but picture wise its imense !
    Anyone debating what to buy go 4 the pw7 and vga convertor !
    Thank you HD
    Regards
    Bobby :clap:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  3. macrosse
    macrosse
    Sep 30, 2004
    33
    paris
    I would also like to thank HD for his numerous comments which have been a great help in letting me understand a little about plasma. (If its only a little its due to my remaining ignorance not HD's posts).
    Bobby_Dazzler could you tell me where you got your VGA cable from? I, like you, have just bought a pw7 (37 inch) with rgb to vga converter (not yet delivered) and have to work out which cables I need to connect it all up. So far the only thing I know for sure is that I will need a vga cable to connect to the plasma, but am unsure of quality/price. I will need a 2 metre cable.
    Advice most appreciated.
    Cheers.
  4. w3dal
    w3dal
    Aug 4, 2002
    4,918
    Chelmsford, Essex
    +543
    I agree!!! :lesson:
    HD's advice in Febuary helped me decide on my purchase of a PW7.
    Top bloke and sorry for all those PM's - :thumbsup:
    Dal
  5. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    macrosse,
    You are going to need a scart to scart lead (assuming that your source device has a scart socket on it and is able to output RGB) and a VGA to VGA lead. Look at the forum sponsors' ads for ideas as to where to buy and how much they will cost.
  6. Bobby_Dazzler
    Bobby_Dazzler
    I got my vga cable from js tech when i bought the convertor. very impressed !
  7. macrosse
    macrosse
    Sep 30, 2004
    33
    paris
    Thanks Piers,
    Ended up talking to AV sales and testing my proposed set up with them over the phone, before buying everything from them.
    I'm connecting up 2 tv sources (cable and satellite) by scart to a master scart controller, through to vga converter. Does this mean I won't have automatic aspect switching between 4:3 and 16:9 or whatever it is? Does this mean black bands on screen or horribly distorted faces?
    I'm using component direct to plasma component board for dvd and scart board in plasma direct to scart in vcr.
  8. macrosse
    macrosse
    Sep 30, 2004
    33
    paris
    :oops: just realised your a retailer Piers
    sorry no offence meant re your competitor.
  9. Andy130
    Andy130
    Mar 17, 2005
    775
    28
    St Helens
    +38
    Just to jump on the bandwagon ^^
    If you had 3-3.5k and was starting from scratch, needing tele, dvd, amp and speakers
    what system would you recommend? I have an idea what I want to go for, but am curious how it would compare to someone in the know such as your good self.
    cheers
    andy
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    My good self? Well i would hold fire for the forthcoming panny 42PV500 before buying anything..... you need to alloocate your budget, is the system for music or just movies? what sources do you have? Do any need replacing to get the best out of the new system? What is the room like? who will use the system?
  11. Andy130
    Andy130
    Mar 17, 2005
    775
    28
    St Helens
    +38
    mainly movies tbh, squarish room, im gunna put the tv in the centre of the room where
    the fireplace was to get the most out of the surround sound. sources? Im payin so the
    gf will have no say (hope she doesnt read this ^^)
  12. NicolasB
    NicolasB
    Oct 3, 2002
    6,041
    Emily's Shop
    +660
    Depending on how long you can wait, some of the new LCD sets due out this summer might be worth checking out - new models from Sharp and Philips, for example. (Maybe also Toshiba).
  13. Andy130
    Andy130
    Mar 17, 2005
    775
    28
    St Helens
    +38
    ideally want a 42" so i dont really think LCD is an option, least for a while it would seem.
  14. dilsher
    dilsher
    we luvs Tom Horny cos hes...well..simply horny innit Tom?
    xxx
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    dil you worry me man, whats the 3 x for? :eek:
  16. dilsher
    dilsher
    Horny
    Ok heres xxxx
    happier now?
    lol..its called affection mate...not even affectation! Nah just a habit of mine and I also go round telling blokes they are darlings too ..but nopes i am not bent that way - mores the pity i say.
    Dil
