Horn Speakers??
Discussion in 'Home Cinema Speakers' started by contactadam2002, Jan 15, 2005.
  1. contactadam2002
    contactadam2002
    Jan 13, 2005
    74
    Does anyone know of any good home cinema speakers that inlclude horn tweeters and midrange, or perhaps have a website? Thanks
  2. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
  3. contactadam2002
    contactadam2002
    Jan 13, 2005
    74
    Thanks for that...any others people?
  4. Knightshade
    Knightshade
    Aug 6, 2004
    1,996
    +43
    You could try these:
    www.klipsch.com
    I heard some a few years back and they sounded OK. The finish back then was very poor but the Americans seem to like them....
    Not sure about availability in the UK. I know there used to be few dealers but i'm not sure anymorre.
  5. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
    Why are you after horns?
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
  7. contactadam2002
    contactadam2002
    Jan 13, 2005
    74
    I have my sound up really loud and horns would generally support that easily without straining too much. Secondly they offer a wider midrange and are the only speakers that could probably compare to the multiplex speakers used in cinemas.
  8. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    http://www.artcoustic.com/News2.htm
    have a look at the Electric Cinema story (scroll down). I saw this before I bought mine. Apparently Channel 4 are using them too. The horns make them much more efficient so they can play rooms this size if needed (or just go really really loud in smaller rooms!!!)
  9. contactadam2002
    contactadam2002
    Jan 13, 2005
    74
    And I quote you on that final statement there '(or just go really really loud in smaller rooms!!!)' as it is bears relavance to the situation I am in now. It must be soo great though to just see how easy your speakers mannage such an intense volume and know that they can mannage so much more (unadivesed though at such potent volumes but you get what I mean)
  10. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    bring it on :devil:
  11. Knightshade
    Knightshade
    Aug 6, 2004
    1,996
    +43
    All very well, but going loud in a smaller room is not always a good thing. Certain frequencies need a large room to 'Fill' otherwise things just boom around.
