Horizontal darkening bar (TM)
Discussion in 'Plasma TVs Forum' started by Geordie Jester, Dec 4, 2003.
  1. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
    Hi guys,
    Another quick question !! :)
    I have noticed sometimes I can see a slowly rolling "darkening bar" moving up the plasma (and looping around to the bottom). It is noticeable on static screens DVD (thru component) (when there is nothing much happening), and was really noticeable on an episode of the Simpsons (the pure untextured colours probably had an effect of highlighting prob). its not a black line or anything, it is a smudgey horizontal stripe that has the effect of darkening the colours in the picture as it moves.
    I have looked for the prob on Cable TV (SCART) and was fairly sure that it was only present thru the DVD source until Simpsons on Sky 1. So it looks like it is possible to see effect on all my sources.
    This kind of implies its the plasma itself, but I was wondering if anyone knows the typical cause of the effect. Is it noise in the cables (or mains supply) or does it sound to you guys like a genuine fault in the plasma?
    My component cables are pretty good (60-70 quid) and short, but my mains power is just thru cheap four-ways etc.
    Any ideas would be appreciated.
    regards
    Paul
  2. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
  3. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    which screen is it?
    I remember when PW6 was just relaesed a few people returned theirs because of a similar problem. Don't remember if anyone actually figured out what it was. Do a search the posts should be dated around september
  4. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
    oops good point. Yeah its the PW6.
    I can't find anything as yet. I will search again.
  5. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
    <bump>
    Any thoughts guys ? Still trying to sort it out. Have tried swapping things out. Not often noticed unless there is a fairly still scene when it catches your eye.
    Found someone else that has experienced the same thing. Thought I would post back here though as the "all-in-one" section is not as lively
    http://www.avforums.com/forums/showthread.php?s=&threadid=107038
    cheers
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,150
    +2,970
    It sounds like a hum bar. Try disconnecting everything then plugging in one item at a time to see when it appears or if it is always there.
    Gordon
