Horizontal Banding XP
Discussion in 'Desktop & Laptop Computers Forum' started by henry1234, Jan 24, 2003.
  1. henry1234
    henry1234
    Nov 15, 2002
    341
    Worcestershire
    +8
    Since installing XP Professional I now have fine horizontal banding running up or down the screen.
    It come and goes but is there about 75% of the time.
    It looks exactly like EMF but it can't be.
    Without changing a thing I booted in ME and it is gone.
    When I use XP it is back.
    I am using a 9500 PRO.
    I posted an AVS but no-one helped, so now it's up to you lot.
    Regards,
    Henry
  2. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    Two thoughts.
    Are you using the same resolution/refresh rate in both XP and ME? You might be 'hitting' a frequency which has some interference on it.
    Have you tried different video card drivers?
  3. graham.myers
    graham.myers
    It could be XP has picked a really low refresh rate.
    I went from 98 to XP everything worked apart from XP slecting a generic low res low refresh driver. I changed it to the "proper" driver and got a better resolution. You could be experiencing a similar thing.
  4. henry1234
    henry1234
    Nov 15, 2002
    341
    Worcestershire
    +8
    I have tried that:
    60hz, 72hz. 85hz. It's all the same except the banding gets tighter the higher the refresh rate.
    I tried the standard Cat drivers that came with the card and the latest cat 3. No difference.
    Very Strange thing: When playing a DVD I can see the lines. If I pause the DVD the lines are still there and moving but if I keep hitting the space bar- pausing and unpausing I can make them go for a while but they soon come back.
    I know this sounds really weird.
    Games are also a bit stuttery and I only score 7395 in 3dmark2001. I also cannot get games to play in anything other than 60HZ.
    Could it be the KT7A abit board I'm using.
    Or maybe XP is putting more drain on the CPU & memory and my 225w PSU struggles but copes under ME?
  5. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I think a new PSU would be a good investment, all sorts of problems go away with a descent power supply.
