Hopefully a simple fix.
Discussion in 'Home Cinema Buying & Building' started by ArmouredShrimp, Feb 25, 2014.
  1. ArmouredShrimp
    ArmouredShrimp
    Feb 25, 2014
    4
    I've recently rezerected a Technics SA-DX950 DTS Amp and am having trouble getting 5.1 through the Xbox One. I'm using a fairly basic set of Samsung satalite speakers which work ok, my main issue is with the sub (Eltax 03949). When I run a test all the speakers work accept the Sub. The connection between the Xbox and the Amp is optical and the connection between the Amp and the Sub is coax although I suspect it may need to be just a basic phono but its been so long this I used his stuff I can't remember. Any suggestions on the Amp set up and connection would be appreciated.
  2. adam81
    adam81
    Oct 9, 2005
    674
    28
    coventry
    +34
    I assume the sub is powered? Might be this..
