Hooking up PS3 on the net through PC
Discussion in 'Playstation Forums' started by Hoax, Jan 16, 2008.
  1. Hoax
    Hoax
    Dec 11, 2007
    393
    +23
    Since Im having a lack of connections and space I was thinking to hook up my ps3 on the net through my pc lan .. I was wondering if anyone else is has it this way at the moment and tell me how you like it or not like it ..
    and how you did it and do I need to buy new cables for my ps3?
  2. jshippey
    jshippey
    Jan 11, 2006
    175
    Kent
    +13
    There's a recent thread on this here
    Have a search around for "internet connection sharing" or "ics" - it's a topic that's often asked about.
  3. Huddo
    Huddo
    Sep 2, 2004
    271
    +40
    I have this set up, since March 07 and I've never had any problems, plays games online fine and very quick at downloading demo's, patches etc seeing I'm currently on just 2MB Orange speed. Only disadvantage is that you need your PC on if you want to play the PS3 online.
    I'm getting a router shortly so this shouldn't be an issue soon.
    You do need a special cable, it's not just the average ethernet cable, from the top of my head I can't remeber what it's called but I'm sure someone will be along soon to let you know.
    In all I give it a thumbs up, as I said only disadvantage is the PC need to be on.
    HUDDO
  4. Darth_terra
    Darth_terra
    Jan 13, 2006
    5,107
    UK
    +948
    It's a crossover cable :)
  5. Huddo
    Huddo
    Sep 2, 2004
    271
    +40
    There you go, I knew someone would know, that's the cable you need !
    HUDDO
  6. Hoax
    Hoax
    Dec 11, 2007
    393
    +23
    you mean crosslink right? or is crossover something else?
    When i used to network alot with a mate we always used a crosslink between the 2 pc's ..
    anyways.. thanks for the info .. I dont mind if my pc have to be on
    its always on anyways that's why I got a very silent pc :)
  7. nichorob
    nichorob
    Jun 23, 2007
    289
    SE London
    +6
    Im just using a bog standard ethernet cable for my PS3 ICS setup.
    I had some teething problems setting up ICS in Windows so UPnP was activated (see my other thread in this forum) to get the sought after NAT type 2 and since then its been perfect. Just as good as being wired direct to the router.
