Hooking sky up to VW11?
Discussion in 'Projectors, Screens & Video Processors' started by Cambo, May 27, 2002.
  1. Cambo
    Cambo
    Mar 10, 2002
    129
    N.Ireland U.K.
    What is the best way to hook my sky box up to my VW11HT?
    Should I make up a Component cable or buy an RGB to S-Vid convertor?
    Everthing else is connected up to my AV amp by S-Video and then out to my Pj.
    My Sky is also distributed around the rest of the house. Don't know if this makes any difference. (wondering if it will affect my viewing of sky on ordinary TV).
  2. Dangerous
    Dangerous
    Hello Cambo
    You need to look at the best signal that the Sky box will output and match that to the 11ht. It won't be component but may be RGB or s-video. RGB is your best bet but you must have an RGB cable with the syncronisation signal on green i.e pin 19 must be connected to pin 11 on the scart plug. So you will need a scart plug to three phono cable made or purchased from somewhere like Keene electronics.
    Dave
