Just a quick question, have seen this deal http://www.avforums.com/forums/comp...meplug-adapters-24-99-delivered-play-com.html
and am considering getting them.
It will be used to connect my router downstairs to my PS3/TV/Wii upstairs. (I will use a ethernet switch for the equipment upstairs)
Where the router downstairs and upstairs equipment are located, there is only one wall socket available which I then have a 5 gang extension/adapter plugged into which then has all the av/pc equipment plugged into.
Will I be able to use these plugged into a spare socket on the gang extension/adapters, or do they have to be directly in the wall socket?
One of the gang extension/adapters is a Monster power conditioner/protection thing, so will this interefere with the homeplug at all?
