Yorkshirelion
Hi all,
Just got a Netgear HDXB101 200Mbps starter kit, plugged it in and installed the software which was a piece of cake, however the reason i bought these was to cure a flaky and packet lossy (made up word) problem.
One is connected to my router downstairs, one is connected to my PC upstairs, when i ping my router downstairs i can ping spikes as follows;
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Stu>ping 192.168.0.200 -t
Pinging 192.168.0.200 with 32 bytes of data:
Reply from 192.168.0.200: bytes=32 time=4ms TTL=255
Reply from 192.168.0.200: bytes=32 time=9ms TTL=255
Reply from 192.168.0.200: bytes=32 time=3ms TTL=255
Reply from 192.168.0.200: bytes=32 time=2ms TTL=255
Reply from 192.168.0.200: bytes=32 time=15ms TTL=255
Reply from 192.168.0.200: bytes=32 time=5ms TTL=255
Reply from 192.168.0.200: bytes=32 time=7ms TTL=255
Reply from 192.168.0.200: bytes=32 time=11ms TTL=255
Reply from 192.168.0.200: bytes=32 time=13ms TTL=255
Reply from 192.168.0.200: bytes=32 time=10ms TTL=255
Reply from 192.168.0.200: bytes=32 time=8ms TTL=255
Reply from 192.168.0.200: bytes=32 time=6ms TTL=255
Reply from 192.168.0.200: bytes=32 time=12ms TTL=255
Ping statistics for 192.168.0.200:
Packets: Sent = 85, Received = 85, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 15ms, Average = 4ms
Control-C
^C
C:\Users\Stu>
Is that just interference on the wiring that is causing this ?
If anyone else that has some could test there's i would appreciate it
Control-C
^C
C:\Users\Stu>
