hi,
i bought 2 orange homeplug "kits" for my house (Orange HomePlug - Orange Accessories) . Each kit contains 2 homeplugs. I have tested both kits separately and they both work. However, when i try using an all four plugs (or 3) at a time, only 1 reciever works.
For example, from my first kit I have 1 plug connected to the router, and the other plug from the kit connected to my PC. This is working fine.
If i use a plug from the other kit and connect it to my PS3, i get no PS3 network connection. The PC network still works.
From reading your FAQ i was under the impression that I should be able to use 3 of my plugs as receivers and 1 as the sender plugged into my router.
Have i bought incompatible home plugs or do i have a different issue?
I think my router is a BTVoyager 1500.
Any help or info would be much appreciated.
Oh, and a happy new year to everyone on this great forum!
