Curly99
This thread is a continuation of the *Part One* thread found here:
http://www.avforums.com/forums/networking-nas/731564-homeplug-faq.html
First Post
I'm aware this needs a serious updateI will try and write an update when I can
What are HomePlugs
HomePlug units enable you to expand your network using the existing electrical wiring within your home. The data travels from one HomePlug to another. No drivers are required, and they are operating system independent. Plug any Ethernet device into the HomePlug and away you go - High speed reliable networking. Truly Plug And Play!
For a more in-depth reading look on wikipedia - HomePlug - Wikipedia, the free encyclopedia
What is the difference between HomePlug and Powerline
Powerline is the technology, HomePlug is a standard for the Powerline technology.
There are two competing chipsets used in the technology. HomePlug uses Intellon based products, whilst other manufactures use a DS2 chipset and a are incompatible.
There is a HomePlug Powerline Alliance. The Alliance's mission is to enable and promote rapid availability, adoption and implementation of cost effective, interoperable and standards-based home powerline networks and products. http://www.HomePlug.org/home
How many HomePlugs do I need
You need at least one pair of HomePlugs. One unit will enter the ring main, and another is used to exit the ring main.
Would HomePlugs work on different mains circuits in my house (rings) ?
Yes, but the rings or circuits (such as upstairs and downstairs) mains must be on the same fuse box / consumer box.
In the US things are a little different. Its common in the US to use Split Phase wiring where the building is split between two separate phases and HomePlug may not be able to cross phases.
How do I setup BT / Wanadoo / Demon / Tiscali / Virgin / and other ISPs with HomePlug technology ?
If you already have a suitable router just add one HomePlug at the router end and one for each PC. The standard USB modem provided free by many ISPs is not HomePlug compatible so you would normally replace this for a Router Modem. Note it is possible to use the USB modem in a Windows Internet share setup with HomePlug, but it is not the ideal configuration. Tiscali's MTU is 1500
How do I setup NTL / Telewest / Cable with HomePlug technology?
Same as above.
How do I setup AOL with HomePlug technology?
To use HomePlug with AOL you need to replace your AOL modem with an AOL compatible ADSL router. AOL uses a special way to communicate through a network so you need a certain model of router. Note the MTU value of AOL is 1400 not 1458 as with BT. Tiscali's MTU is 1500.
What do I need on my PC to make HomePlug work?
Your PC must be compatible with Internet access and have a LAN / Ethernet Port.
I have an Apple Mac, will HomePlug work properly?
Yes HomePlug works on most Apple Macs without using any software you just set the Mac to TCP/IP Internet.
How do I connect a router with a LAN Socket to my Computer - it only has USBs?
Install a LAN card or select a suitable adaptor.
I already have a router with 2 or more ports will HomePlug work?
Yes connect one HomePlug to the Router and one HomePlug to each PC (or xbox etc) in the house.
Do I need to put a HomePlug into the router for each of my computers?
No only one HomePlug is needed at the router end.
How fast is 14Mbps and 85Mbps in Mega Byte per second?
approx 1.75 MBytes for 14Mbps and 10.6 MBytes for 85Mbps
Note ADSL and Cable connections are provided in Mbps, NOT Mega Bytes per second:
Here are some examples of ADSL to Bytes per seconds
Half Meg 512 connection = 64KBytes
One Meg 1024 connection = 128KBytes
Two Meg 2048 connection = 256KBytes
Four Meg 4096 connection = 512KBytes
Ten Meg 10240 connection = 1280KBytes
Twenty Meg 20480 cinnection = 2560KBytes
What is HomePlug AV?
This is the new 200mbs standard designed for use with Hi-def streaming.
Are all HomePlug versions compatible?
All 14mbs HomePlugs regardless of manufacture are compatible with each other as they all adhere to the HomePlug 1.0 standard. All 85mbs are interchangeable too as they adhere to the HomePlug 1.0 Turbo standard. HomePlug 1.0 and 1.0 Turbo are interchangeable so you can mix and match both 14 and 85mbs as well as manufacturers.
There are 2 makes of powerline chipsets. Intellon and DS2. The majority of manufactures use the Intellon chipset and adhere to the HomePlug standard and are interopable. However those that use the DS2 chipset cannot be used with Intellon based products. Phillips' HP products and Netgear's 200mbs units (HDX101) use the DS2 chipsets.
HomePlug AV (200mbs) can coexist but will not inter-operate with the HP 1.0 and 1.0 Turbo standards. This means you can have one set of HP 1.0 units and 1 set of AV units but they can't see each others kit. The manufacturers claim there is no drop in performance when mixing these but tests (on Tom's Hardware and SmallNetBuilder) indicate that performance can drop as much as 58%.
What is the actual speed I can attain with HomePlugs?
The ratings of 14, 85 or 200mbs are theoretical maximums. You will never achieve these speeds. This figure also includes the overhead of the data transmission protocol, for example the HomePlug AV (200mbs) standard has a maximum data rate of 150mbs. Additionally, the mains ring is a hostile place for data and pushing through the maelstrom of noise on the line slows down the packets. There are ways to speed up transmission as best you can, for example tighten the wires in all the outlets in you house (WARNING: Turn off the power first!). I have gone from 85mbs to 115mbs throughput by doing this one task (when using Netgear 200mbs plugs). It is not unreasonable to assume you will get approx 50% of the rated maximums. There are also various threads around the net that highlight issues with switched power devices such as phone chargers and hairdryers. Unplugging phone chargers can also increase performance.
If you are using Netgear's HDX101 200mbs units, the latest firmware implements a new feature called auto enable notches. Notches having something to do with reducing interference to hand-radio frequencies and this will lower the performance of the powerline network somewhat. Performance can drop as much as 25% becuase of this feature. Netgear's gui configuration program offers no option to disable notching, but you can with the commandline tools such as ihcp_client. See here for details - Got better performance on the original firmware? This may be why... - NETGEAR Forums
When streaming content around the house using powerline technology then you are sending UDP packets of data. Most HomePlug products (definately Netgears HDX101) are optimised for sending UDP streamed traffic. If however you need to transmit lots of TCP traffic from a windows machine (mostly file copies etc) then you can amend the TCP window size to boost performance from the default 8K to 128K
Which HomePlug should I use?
This entirely depends on what data you want to distribute around the house. The 14mbs units should only be used for low transmissions equipment, for example you can purchase security cameras with HomePlug built in and these are 14mbs devices. Xboxes, PS3s etc should be using a minimum of 85mbs. If you wish to stream a lot of video or VoIP and/or Hi-Def you should be looking at 200mbs models.
How many HomePlugs can I use at home or in the Office?
HomePlugs are like old School Ethernet; they run on half-duplex. So only one device can send at a time. Technically 10 is probably the limit due to throughput in theory up to 254 could be used. Be aware that if you have BT Vision you may already have Comtrend's (DS2 based) 200mbs adapter in your package. Be carefull if buying additional powerline units - you may need to buy compatible DS2 based products.
Is software provided with HomePlug and how do I use it?
The software (usually only for Windows) allows transmission checks and adjustment of network names (encryption). Software drivers are not required for HomePlug the units are plug and play.
Do I lose the use of my power socket?
Yes, normally. Most HomePlugs are like normal power devices, they use up the socket you plug it into, some even are so large (Netgear for example) that they prevent larger items to be used in the socket next to them, for example transformers etc. You can get HomePlugs with a through socket so you can still plug a device into them. A bit like the old cube style triple adapters you can get.
Is HomePlug secure?
Yes it is preset with its own 56bit encryption system to protect your data. HomePlug AV adopts a 128bit encryption system.
Dont forget to check the security options on any wireless devices in the house. If an outsider can access the wireless network, they also gain access to the homeplug-connected computers, and the homeplug security is useless.
Can my neighbour steal my internet connection if he has a HomePlug?
No, the electricity meter acts as block on the signals that are transmitted across the network, so there is no chance of them leaking out on to the public wiring and your neighbours picking them up.
I dont have a wired connection only wireless. Can I still use HomePlug?
Yes. Some manufacturers (such as Devolo) produce a wireless-g extender - http://www.devolo.com/co_EN_cs/produkte/dlan/dlanwirelessext.html
Can I use my Xbox on HomePlug?
Yes. The XBOX 360 has a 100mbs Ethernet port built in. Just plug it into the HomePlug
Fix: Xbox doesn't work with Windows Media Centre when connected by HomePlug.
Some makes of HomePlug work with IGMP V2 - windows extender uses IGMP V3. You need to modify the windows registry and set the Media Centre to IGMP V2.
Please see the following link on how to modify the registry.
You Cannot Configure Windows XP or Windows Server 2003 to Use IGMP Version 1 or Version 2 Support
Can I use my Play Station 2 (PS2) with HomePlug?
Yes you will need a network adapter available from Sony, Amazon or another online retailer.
Can I use my Play Station 3 (PS3) with HomePlug?
Yes. The PS3 has a 1000mbs (gigabit) Ethernet port built in, just plug it into the HomePlug..
What stops HomePlug from working, will they work with extension Lead?
Avoid surge protected / Filtered mains extension blocks as these block the HomePlug signal. Long extension leads will degrade the signal so it is best practice to plug the HomePlug directly into a wall socket. I personally have one HomePlug in the wall socket and one plugged into a 4 gang and achieve 115mbs approx. There are also various threads around the net that highlight issues with switched power devices such as phone chargers and hairdryers. Unplugging phone chargers can also increase performance. Be aware that if you have BT Vision you may already have Comtrend's (DS2 based) 200mbs adapter in your package. Be carefull if buying additional powerline units - you may need to buy compatible DS2 based products.
How can I test the performance of my setup?
You need some kind of bandwith measuring tool. While most homeplug manufacturers distribute utilities that measure their products performance, in my experience they can be a little misleading. They measure the peak performance between the devices not a real world throughput test. Enter iPerf. You will need two PCs one on either side od the ring main. One runs as a client, the other as a server. Its deisgned as a TCP/UDP monitoring tool not just for homeplugs.
http://dast.nlanr.net/Projects/Iperf/
on the client you would .. iperf -c <server address>
on the server you would . iperf -s
heres an example .
Code:node2> iperf -s ------------------------------------------------------------ Server listening on TCP port 5001 TCP window size: 60.0 KByte (default) ------------------------------------------------------------ [ 4] local <IP Addr node2> port 5001 connected with <IP Addr node1> port 2357 [ ID] Interval Transfer Bandwidth [ 4] 0.0-10.1 sec 6.5 MBytes 5.2 Mbits/sec node1> iperf -c node2 ------------------------------------------------------------ Client connecting to node1, TCP port 5001 TCP window size: 59.9 KByte (default) ------------------------------------------------------------ [ 3] local <IP Addr node1> port 2357 connected with <IP Addr node2> port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0-10.0 sec 6.5 MBytes 5.2 Mbits/sec
Last Post
I did have my Homeplug plugged into surge protectors, and they did work - although I've found they work faster when plugged into a non surge protected socket.
However, I don't have double sockets on my wall, so at the moment I've plugged a multi/double socket adaptor into a socket, and plugged the homeplug into one and the surge protector into the other.
Is this electrically safe? Also, are there any surge protectors that have non surge protected sockets that I could use Homeplugs with?
Curly
