Homemade Component Cables?
Discussion in 'Cables & Switches' started by fordster, Dec 2, 2004.
  1. fordster
    fordster
    Aug 9, 2004
    151
    I've got my CAT 5 cable and I'm going to make up some speaker cable this weekend. This got me to thinking about component cables and whether a homemade set of cables would be just as good (and a lot cheaper) than commercial ones.
    At the end of the day component cables are just digital 75ohm coaxial cables with phono plugs on the end. That's nothing special and the cable is cheaply available from the like of Maplin:
    http://www.maplin.co.uk/Module.aspx?ModuleNo=9512&TabID=1&source=14&doy=2m12
    This cable is £1.99 per metre and looks to be ideal for the job. They sell phono plugs that also cost £1.99 each:
    http://www.maplin.co.uk/Module.aspx?ModuleNo=44031&TabID=1&source=15&WorldID=&doy=2m12
    Taking the standard 1 metre length this means you could make a set of cables for £18. How can you therefore justify spending £60+ on a set of manufactured cables?
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Check out our DIY forum, you will find many of us have gone down the home made route already.
    Cheers, Mylo
