Homegroup gone, what now?
Garry123
So i upgraded Windows 10 and homegroups has gone. Why remove something so simple.
So how do I now see my other PC on my network?
next010
It was removed because according to MS nobody used it.
The manual method of adding/sharing network folders was always present in the back ground.
To map a network share all you should have to do is go into the network section of explorer/thispc and browse around to find what your looking for [logging in using user/pass belonging to that system] then select map it from context menu.
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
