homecinema
Discussion in 'Home Cinema Buying & Building' started by lnewey6, Mar 20, 2005.
  1. lnewey6
    lnewey6
    Nov 10, 2003
    196
    derbyshire
    +3
    has anyone tried to fit a homecinema in a room 8foot wide and 10 foot long please help
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,149
    UK.
    +2,670
    Yes,
    What type of display will you be using? If it's a projector, you might get more help in the relevant forum.
    Gary.
  3. lnewey6
    lnewey6
    Nov 10, 2003
    196
    derbyshire
    +3
    its going to be a 42 inch plasma
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,149
    UK.
    +2,670
    I don't see any problems fitting the plasma into that size room, excpet it may appear a bit small on the wall :) Sound should be pretty good too providing you don't have the volume so loud that the audio is bouncing all over the place.
    Have you considered something like a projector? It will give a bigger image than the pj, and look far more cinematice too. You could fit it on the ceiling and make a DIY screen for under £30. PJs can cost under £1000 for a good quality model - checkout the pj forum for more info. They're pretty easy to set-up - plug and play mostly, though you can tweak if you want.
    Gary.
