Kacper1
I want to build a home theatre system in my new place. It will be my first installation. I have some experience in technology, and I know what my needs are. However, I am not experienced in the audio world, and therefore I need your opinion and help.
1. The place dedicated for the home theatre can be described in a rectangle. This space's cons are: a window on the right, a passage on the left, and an open space above towards the dining area. I am aware of how important acoustics is. I want to hire a company for this purpose that will deal with the soundproof of this area. If you have any suggestions for this part, I am open to any suggestions.
2. After many hours spent on the Internet, I decided to buy a Bowers & Wilkins speakers set. Here's the list:
Front: 2x 703 S2
Middle: 1x HTM71 S2
Rear: 2x 706 S2
Subwoofer: 1x DB4S
Ceiling: 2x CCM664
2.1. Do you think it's a good setup? I think it's worth the price.
2.2. Is it worth buying a second subwoofer?
2.3. Is it worth buying 4 ceiling speakers? Will I feel the difference in such a small space?
3. I have no idea which receiver to choose for this audio set. My requirement must be 4k / 120Hz passthrough support. Below is a list of amps which I researched:
Yamaha CX-A5200
Denon AVC-X6700H
Marantz SR7015
The budget I have is 10k GBP and I don't want to exceed it.
Front: 2x 703 S2
Middle: 1x HTM71 S2
Rear: 2x 706 S2
Subwoofer: 1x DB4S
Ceiling: 2x CCM664
Yamaha CX-A5200
Denon AVC-X6700H
Marantz SR7015
