Home Theatre Advice
tredsaw
Established Member
Joined
Oct 8, 2007
Messages
131
Reaction score
11
Points
79
Location
Near Middlesbrough
After some advice for my sister who is looking to buy a 5.1 setup alongside either a 42PZ80 or 42PZ85. The budget isn't very high, looking at no more than £250 preferably. The system will be mainly used for SD TV and Upscaling SD DVD's with the possibility of buleray/HD-DVD shortly.
Just looking for some expert advice on what her options are.
At £250 and the need to possibly add Blu-Ray (HDDVD is dead) you should really be looking at a AV starter system like this http://www.petertyson.co.uk/ebuttonz/ebz_product_pages/yamaha_av63.shtml
This will allow you to connect upto 3 items with digital 5.1 sources.
DVD
SKY+
SKYHD
PS3
PS2
XBOX360
Etc Etc.
And also has direct 5.1 input, so if your future Blu-Ray player has 5.1 direct out it can be connected via this method to give DolbyHD.
With most all-in-one systems you are lucky to get one optical input for a 5.1 source.
http://www.yamaha-uk.com/pdf/product_bulletins/RX-V363.pdf
Lyngdorf MXA 8400 - Premium Power Amp Review Teaser #homecinema #poweramplifier #hometheater
Back
