Home theater system help (starting from Onkyo Tx-NR515)
Discussion in 'Home Cinema Speakers' started by nutcat, Mar 13, 2013.
  1. nutcat
    nutcat
    Mar 12, 2013
    2
    This is my first post. after viewing tons of threads in the forum, I am still unclear of what I should buy.
    I just pulled the trigger on a refurb Onkyo receiver (NR515) as my first HT starting point. I know it is an entry level unit so it has its limit (80w/channel), I would like to know what speakers you recommend..
    After reading many threads, I think I will take the advice of buying the main two speakers first and then sub and then center and then surround. So 2.0 - 2.1 - 3.1 - 5.1
    So please help me with bookshelf recommending. Here is the what I want:
    1. I would like a good enough pair that is not an overkill for my entry level AVReceiver,
    2. my budget is $300 at most but I am very OK with paying less. (Let me know if my budge is too low or too high for my receiver)
    3. Considering that I will buy the center later to pair with these, so please recommend the paired center as well.
    4 my room is ~200 sqft. 50/50 movie vs music.
    Thanks.
  2. nutcat
    nutcat
    Mar 12, 2013
    2
