Home Theater Setup With Panny 42v20d, Sony S370, Sony Amp DH310 & Acoustics 2000 5.1
harbuu
Hi Friends,
Need your help ... to fix up my Home Theater.
Got Panny 42v20d - Bought in Bangalore india
Planning to by Sony Blue ray S370, Sony DH 310 and Q A 2000 5.1 HOME Cinema.
Will all put together will give the out put, of is expected from the home theater. I am a lay man in getting this setup, so i need to get it right - require your help.
Usage :
1. Tata Sky with HD - 55%
2. DVD / Blue ray - 25%
3. Audio CD (MUSIC) - 10%
4. Planning xbox - Sony - 10%
Kindly suggest ....... Thanks a ton in advance to all.
davepuma
Is there such a thing as a Sony STR-DH310? I would be looking at the STR-DH810 if you want to both future proof your setup and also give you HD audio from bluray. I am not familiar with the 310 but here in the UK, the STR-DH510 is available and although some of the specs look okay, it has clip connections for speakers and it weighs about the same as a tin of biscuits. It is probably built from the same stuff too. In other words, I would avoid it and look further up the range. However, I don't know what else is available in India, perhaps you can post what sorts of prices the other makes cost e.g. Denon, Pioneer, Onkyo and Yamaha.
