Home security system and cctv
Discussion in 'Smart Home, Climate Control & Security Forum' started by Guppymc, Jul 19, 2018.
  1. Guppymc
    Guppymc
    Jul 19, 2018
    Liverpool
    I have bought a house and the previous owner has decided to take the alarm system and cctv cameras that are all wifi linked with him unless i pay £1000+. Without knowing what brand of system how easy is it to use existing wiring to put in a new alarm system and cameras
  2. mushii
    mushii
    Apr 3, 2003
    2,241
    116
    Stoke On Trent
    +1,201
    The alarm SHOULD be fairly straightforward, although I have seen some bizarre use of alarm cabling. Likewise the CCTV SHOULD be fairly straight forward you just need to ascertain whether it was a Digital (CAT 5/6 Cable) or Analogue (RG6 or RG59) system. Depending on Cameras and how many there were £1000 may or may not be excessive, likewise alarms run from £10's to £1000's depending on make and model and numbers of zones, keypads etc.
    Assuming all of the cabling is good and usable you should be able to replace both in 2 days max.
