Home Network Using Electricity Cables
Discussion in 'Desktop & Laptop Computers Forum' started by RichardB, Jun 13, 2005.
  1. RichardB
    RichardB
    Sep 28, 2004
    34
    Hi folks, has anyone got any experience of this home networking using your electricity cables malarky?
    BBC Story
    There are some products for sale here:
    Solwise
    It doesn't seem to be prohibitively expensive and other than interfering with shortwave radio there are no major problems that have been encountered with it so far.
  2. The Dude
    The Dude
    May 21, 2004
    5,114
    Beverley, East Yorkshire
    +1,384
    I dont, but I have lots of experience with power over ethernet devices, and they work faultlessly. I cant imagine doing things the other way round will cause any major problems for the designers.. :rolleyes:
    I use Solwise a lot for Wireless Products, they really know what they're talking about.
    If they sell it, I'd say it will definitely work..
  3. PAH
    PAH
    Jan 29, 2002
    1,129
    48
    +63
    The speeds are currently slower than wireless so their niche is really for those that either can't use wireless (have lots of thick walls) or don't want to start messing the house up by laying new cables.
  4. sjl
    sjl
    Jan 1, 2001
    81
    I have been using a pair of these for over a year
    http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=1806
    I have a switch in the front room and I connect the Tivo with Cachecard and a Dell MP3 player that I bought off of the for sale board on here.
    Both of the above items run at 10mbps so speed is not an issue for me.
    Been absolutely flawless and were very easy to setup.
    Steve
  5. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    I recently installed a 14Mbps for setup at in my sisters house - 3 wallplug ethernet adaptors. Totally painless install, with nothing to configure - just plug 'em in and off you go.
    If you need more bandwidth, 200Mbps products are due very soon now. BroadbandCarrier should have some soon (and they're very good people to deal with).
    Cheers, Carl.
  6. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,108
    Manchester
    +713
    There are two sides to this. The BBC article was quite correct about interference issues. However PLT (Power Line Transmission) does indeed work.
    Because elecrticity wiring has an undetermine impedance, efficiency will vary ; likewise the incidence of unintended "virtual antennas" and peaks in frequency response is totally unpredictable.
    I am affected by this from 2 conflicting angles :
    1) I work for a company who makes ICs that enable this technology.
    I have to at times give technical support to UK companies designing such systems.
    (Incidentally 2 such companies I was involved with have gone bust in the last 2 years).
    2) I am a radio amateur ( or "radio ham" ) and , therefore, stand to be affected by interference thus caused.
    The Homeplug standard is a USA thing, Europe is supposed to be working on an ETSI standard for it ; PLT is commoner in Germany than in UK (fortunately).
    If you want to read more here are a couple of links :
    http://www.rsgb.org.uk/emc/emcwebsite/index.html#plt
    http://p1k.arrl.org/~ehare/bpl/Guidance_for_field_trials.html
    http://www.homeplug.org/en/index.asp
    Chris Muriel, Manchester
