Home Network Cabling
Discussion in 'Smart Home, Climate Control & Security Forum' started by gillettos, Nov 25, 2017.
  1. gillettos
    gillettos
    Mar 2, 2011
    7
    Not sure where to really post this, but all relates to Smart Home / future proofing so here goes........
    I'm looking at 'future proofing' my house..... and remember a few years back going to a home building show at the NEC and came across a stand called 'Single point networks'. Basically one custom designed connection which can handle everything. They promote the fact they use cat-8 cable which is fine for HD, but like now what about 4K.......??
    Just wondering if anyone has any advice / suggestions to what methods I can use.
    If it means running separate cables throughout and having the relevant faceplates then so be it, just got a feeling there must be something out there.......
    Any advice much appreciated
    Cheers :0)
  2. Jamie
    Jamie
    Jun 27, 2007
    5,434
    2
    Harrogate
    +1,414
    The ultimate future proofing is making easy to use conduits and cable routes that make running anything you've not got easy.
