Home made screen
Discussion in 'Projectors, Screens & Video Processors' started by Gene, Aug 10, 2004.
  1. Gene
    Gene
    Aug 5, 2004
    41
    London
    Hi, I was looking to make my own screen, but instead of making a fixed screen like many others, i wanted to make one that looks like a roller blind. :)
    I'm going to buy 1:1 gain material from drh.
    Anyone know where I can get the roller casing that is used in roller blinds, so that I can attach the screen material to that and just use it like a regular roller blind. I don't want to have to buy a normal roller blind. Just the actual casing and roller mechanism.
    Obviously you can see i'm on a tight budget. :D :D :D
  2. Kramer
    Kramer
    Moved to projection screen forum.
  3. Gene
    Gene
    Aug 5, 2004
    41
    London
    oops sorry, I didn't realise there was a screens forum.
    Thanks Kramer for moving this.
    Maybe I might get some replied here. :laugh:
  4. Gene
    Gene
    Aug 5, 2004
    41
    London
    I've just seen some posts about using blackout lining and they seem to work ok.
    Anyone know where I can buy blackout material (I went to Paul Simon curtains but they only do ready made blackout lining)
    Should I go for the blackout lining or stick with screen material from DRH?, will there be a big difference in pic quality ?(projector is an Infocus X1).
  5. inzaman
    inzaman
    Dec 16, 2002
    7,883
    Derby
    +935
    You can actually buy a black out roller blind, from ikea i think most people get them from.
    Personally i couldnt get on with bo material even when painted icestorm 5/6 mix so use screen goo instead.
  6. Gene
    Gene
    Aug 5, 2004
    41
    London
    Got my screen material from DRH Screens. 6 foot by 5.
    Its a great improvement over the yellow wall I was using for the last couple of days!
    I must say thanks to DRH, as I visited them yesterday, and they are a great bunch of people (no I don't work for them or am not affiliated with them :) )
  7. monopole
    monopole
    Which screen material did you go for? White, grey, high gain? Which projector are you using? Thinking about making a screen of my own for when i get a projector (will have to demo a DLP first - infocus 4805 - to explore the rainbow issue) and the choices make my head hurt sometimes.
  8. Gene
    Gene
    Aug 5, 2004
    41
    London
    I got the matte white and using with an infocus X1. Give a great picture. :)
