Home made DVD-R skipping and Jumping, any ideas?
Discussion in 'Blu-ray & DVD Players & Recorders' started by w3dal, Jun 30, 2004.
  1. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    Hi All,
    My Boss brought in a DVD-R of his sons football team that the manager had made for the players. When he watches it in his DVD player at home (of on a PC at work) after a few minutes it jumps and skips. Go to another chapter on the disc and after a while does the same.
    So i was thinking i would use dvd-decryptor to create a new image of the disc and then burn it to a decent DVD-R at 2x speed and then see what happens.
    The disc itself looks ok, but am not sure at what speed it was burnt at or what software they used to make/burn these discs with.
    Do u think its worth me creating a new image of the disc and then re-burning or do u think that the problems which are on the disc already will be transfered to my burn.
    Not done something like this before, so any advice would be apprecaited you never know i may get a pay raise out of it, saying that if i cant sort it then it will be my P45 - ;0)
    Dal
  2. RBJTech
    RBJTech
    May 7, 2004
    583
    43
    Kent, England
    +101
    Yep - agree 100% - it's almost certain to be crud media that's causing the problem.
    DVD drives in PC's seem to be a lot less fussy on media so I would do exactly what you have suggested.
    Use DVDDecrypter in ISO mode to Read the disk, then use some decent media (Ritek Grade A or Branded Disk) and do an ISO Write.
    Good luck with your pay rise !
    :laugh:
  3. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    Hi Mate,
    Thanks for the reply.
    I was going to use NERO to burn the image but i guess i could use dvddecryptor to burn the image aswell. - any suggestions???
    Currently using Datasafe Ritek's so fingers crossed they will be upto the challange.
    ill let u know how i get on tonight.
    Dal
  4. RBJTech
    RBJTech
    May 7, 2004
    583
    43
    Kent, England
    +101
    Nero, DVDDecryper... they are all the same in an image mode so use what you have.
    Datasafe Riteks are (IMO) very good disks - you should have no trouble with those...
  5. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    I think ill go for create the image in dvd-decrypter and then burn it using that too.
    Not done that before so it will be worth testing it out.
    if not ill use NERO
    Dal
  6. w3dal
    w3dal
    Aug 4, 2002
    5,057
    Chelmsford, Essex
    +590
    Well i just made and burnt the image using DVD-Decryptor and works fine.
    All i need todo now is get that pay rise - ;0)
    Dal
