HOme made DVD on DV88
Discussion in 'Movie Forum' started by Tom Christensen, Feb 1, 2004.
  1. Tom Christensen
    Tom Christensen
    I have a Arcam DV88 with firmware 1.81 and loader LO16.
    My problem is that i cant play home made DVD perfect.
    Alot of brand i cant even get to start, and those i have tried that worked keep stopping althrough the movie.
    Does anybody have a brand of DVD that works???
  2. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    Try the compatability charts over at dvdrhelp.com - also the users' comments might prove useful.
    I don't have this player but have found that hitting the correct burn software/media combination for your player can be a bit time consuming! Get RW media to test I'd advise!
    Hope this helps
    dr_m
    PS
    John Dawson from Arcam used to frequent these forums (been a while since I had a look around so he might not be around aymore) but he might advise you also.
  3. -Spike-
    -Spike-
    May 17, 2001
    1,625
    E.Sussex
    +297
    Tom,
    Post this in the Arcam Forum, found further down the main page.
    As dr_mabuse says John Dawson still regularly frequents, so he or another will definitely be able to help you in there.
    Best of luck :)
