Home made DVD disk stammers
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mziporen, Aug 14, 2005.
  1. mziporen
    mziporen
    I have imported to my computer an AVI video file, which can be viewed nicely by video viewing programs (like ULEAD, or Windows Media Player).
    Using Pinnacle's STUDIO 9 (a video editing program), I made out of my AVI file a project and burned it onto DVD disk.
    I have burned the project on 2 different kinds of DVD disk media, (one was
    Teak and the other one was MMI?), but the problem was not solved.
    The problem is:
    Playing the DVD disk - it "stammers", meaningly - it stops for some seconds, then continues playing.
    It happens both when I use the disk on my Saloon DVD player, or at my computer. (The problem is less acute at my computer than at my DVD player, but still it exists in both).
    Can anyone suggest a solution or try to think about the factors that can cause this problem?
    Thanks for any idea.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    It could be a few things.
    Dropped frames during capture, but these should be reported by the software.
    Background programs affecting the performance of the PC - you should stop ALL background programs when video editing.
    HDD getting full up, or even fragmented. Make sure you have at least double the space needed for the AVI files - that's approx 2x 14Gb per hour of footage. Defragment the HDD before starting any project.
    Burn the disc at a slower speed. This does help to make a more reliable disc.
    I suggest you head over to the 'camcorder & video editing' forum here and have a good look around. If you can't find the answer to your problems there (and my above suggestions haven't helped either) then post the thread again as there are many Pinnacle Studio users on there.
    Good luck,
    Mark.
  3. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
    Moved this to the Videio Editing forum
  4. russ hirst
    russ hirst
    Jun 18, 2005
    30
    11
    Harrogate, N Yorkshire
    I seem to remember having similar problems when I first started burning projects to DVD. I changed the type of DVD discs I used and it cured the problem.
    I previously bought DVD+R discs and changed to DVD-R discs. After that, I have never looked back. Don't know if it will help but hope you get sorted.
  5. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    Are you burning the DVD from within Pinnacle? I know that when I used to use Pinnacle, I had no end of problems trying to do this.
    If you are, then try creating the DVD image onto your hard disk (there is an option within Pinnacle to do this), and then use another program such as Nero to do the final burn.
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    melliott1963 - You have a PM
