Home Laptop movie Editing
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by toeclogger, Apr 23, 2007.
  1. toeclogger
    toeclogger
    Hi looking for a cheapish good way of editing movies captured on http://www.ebuyer.com/UK/product/124848/
    on my laptop. Anyone recommend a way of getting the movies onto the laptop and some decent S/W to go with it?
    thanks
    :lease:
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    It's a miniDV camcorder, so the best (only?) way is to use Firewire. Do you have a firewire port on your PC? If so, get a firewire cable (probably 4 pin to 4 pin, depends on the connection on the laptop).
    If your laptop doesn't have firewire but has a Cardbus (PCMCIA) slot then get one of these (comes with a cable and even some editing software)
    http://www.dabs.com/ProductView.aspx?Quicklinx=3ZR0
    Or if it has an express card slot, one of these
    http://www.dabs.com/ProductView.aspx?Quicklinx=4FYK
    For software: my favourite is Sony Vegas, recommend the Movie Studio Platinum edition. Others to consider: Premiere Elements, Ulead Video Studio....
