Home Installation Online Recomendations
Discussion in 'Home Cinema Buying & Building' started by chris_bham, Aug 4, 2013.
  1. chris_bham
    chris_bham
    Apr 2, 2009
    22
    Hi I am after a TV / Speaker installation. Work I would like done is a TV (47 inch) fitted on a bracket, which I have already bought.
    With all wires concealed into the walls (all walls are plaster board as far as I am aware). Running to a book shelf that will house my equipment (this will not need to be connected).
    All speakers from my blu ray sony home cinema system are wall mounted (no flooring will be down and can be ran across the floor) and wires concealed in the walls.
    I do have a budget of approx. £300 - £350 for this job
    Can anyone recommend any companies online who would offer this service with competitive prices. I have looked online and found a few just wanted to know if anyone knew any hidden gems.
    I have so far emailed AV installs, Richersounds and had a quote of 350 (plus vat) from Master AV services.
  2. Gaspode_TWD
    Gaspode_TWD
    Jun 3, 2008
    720
    Thame
    +69
    You're more likely to get suggestions if you can indicate the area of the country where the work is to be done.
