Home Entertainment AV Unit
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Bales1983, Jun 16, 2004.
  1. Bales1983
    Bales1983
    Hi all,
    My new home entertainment kit is coming together well, got a new Sanyo 32WN5 and a DVD/Surround Kit, just need shelving and and storage for the equipment and DVD's now, Ive looked about a bit but cannot find something that is quite like the one i have drawn a diagram of, has anyone come across one of these before?? Its about 5ft long, and height doesnt matter (as long as its less than 8' 6"!!) I would like the bottom to be about 2 feet wide up to the tv layer then about a foot wide after that, hope everyone can follow that??
    Thanks for all who help me
    Lee
  2. wizbongre
    wizbongre
    Jun 24, 2003
    594
    Liverpool, Merseyside
    +63
    The only thing I can suggest is making it yourself...
    Its really easy, just measure up all the pieces and go to your local B&Q warehouse (other timber stockists are available ;) ) with a drawing and get them to cut all your pieces for your. I've done this a few times and if you have got your measurements spot on all you have to do is screw it all together. Bit like a diy flat pack!
    Good luck!
  3. John
    John
    Dec 13, 2002
    11,399
    +3,030
    have a look at ikea , I'm sure I've seen something like that there
  4. John
    John
    Dec 13, 2002
    11,399
    +3,030
