Vlada011
Hi people,
I look speaker system for me for Home Cinema, movies, music and off course PC will be connected.
Sound Card is Sound Blaster ZxR but later I will replace op-amps for improvement.
I can't afford something ultra expensive and I will need to buy separate first speakers than AV reciver.
Budget is up to 1000$. I saw 2-3 good options...
One is Q Acoustics 3000 5.1 but I see people are not satisfied with his subwoofer and use usually SVS 1000. Other option is cheaper Wharfedale DX-1 SE with AV reciver...
If I go on Q Acoustics I would bought first 3020 Speakers New and Center and for Subwoofer I would check something else.
What you say is it something better? I hear Elac Uni-Fi UB5 are good and Dali Zensor 3.
For reciver I would like most Marantz... But all of good Marantz are above 700. From other side Yamaha have some interesting for arround 500-550, as RX A660 Avenger.
What you think?
At the end when I build 2 Front + Center + Subwoofer I would MAYBE add 2 more as rear.
Off course same model as front. But for now 2+1+1
What you think?
