home cinema
Discussion in 'Home Cinema Building DIY' started by jburchett, Apr 11, 2005.
  1. jburchett
    jburchett
    has any one manage to get a home cinema in a room mesuring 9 foot by 6foot including projector
  2. digisocialist
    digisocialist
    Sep 5, 2004
    477
    Yorkshire
    I'd say, very optomistic but not impossible... it woudn't come without it's compromises.
    I'm in a room about 13ftx13ft but my PJ is 9ft from the wall onto which it projects and I get a 5ft image... that said, sitting at that distance can feel a little 'on top' of the picture. I imagine you'd be projecting from about 8ft and sitting from that close could be somwhat uncomforatble. The acoustics may also be a little opressive, Is this room your only option? If so, a Plasma and small satalites might be an option....
  3. Techno Freak
    Techno Freak
    Aug 24, 2003
    312
    16
    North-East
    My two pence worth - I would go plasma in that size room also.
  4. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    I'd probably also recommend a Plasma with tihs size room, i dont know whether the accoustics would suffer though, as stated above maybe satellite speakers.
    My room is 11x11 and my pj is about 10 foot back, where i sit, which does throw a 6.8 foot wide image, i do feel that this is slightly too big though and will go 6 foot in the coming months. This also opens up more pj choice as it gives more flexibility in the throw distance.
  5. hammy2891
    hammy2891
    my hc room is 6ft wide x 10ft with pj on screen just under 6ft,not ideal size room i know but compromises had to be made,my veiwing position is about 8ft back on a 2 seater leather setee with the htpc to one side on a 17" tft monitor,speakers are mission m71 all round with a kef center these are small but big enough to fill the room,like i stated not ideal but i'm very happy and so is she who must be obeyed,a smaller screen may give better pq and leave room down the sides for speaker positioning but that is something for the future as getting hitched soon so a spending freeze has been placed on me,
    go for it you'll love it.
  6. gaz
    gaz
    Oct 24, 2004
    90
    i recomened using a 14" portable in that room lol.......................................
    Only joking my room is 6' wide i have seating for 7 and and length is just over 14' i'm projecting at 81" on a diagonal my front row of seating is about 8'6" back from the screen and i have no problems and enjoy the ride:
    [​IMG]
  7. hammy2891
    hammy2891
  8. sheffieldeagle
    sheffieldeagle
    Jun 30, 2004
    131
    +3
    My converted spare bedroom is 6 x 9 ft and with my PLV Z2 I manage to acheive a 6ft screen size. Both the seating and projector are on the back wall. I say go for it.
  9. lnewey6
    lnewey6
    Nov 10, 2003
    194
    derbyshire
    +3
    thanks for all the replys pictures will be posted in due time do any of you use yours for everthing any one got plasmas in their as well
  10. hammy2891
    hammy2891
    i use mine for viewing f/view via component from a netgem,dvd via samsung hd745 and htpc via dvi using theatertek.but i still got an old 25" jvc telly for "her" and all in a room 6x10.
    just watching lotr in high-def via htpc while surfing the net as well,
    see what you're missing.
    hammy
  11. sparkrite
    sparkrite
    Feb 16, 2005
    926
    63
    on top of a mountain in Wales
    +284
    Just converting my garage into HC set
    Internal size after dry lining...4.5 x 2.4 m
    kit bought:-
    sanyo pl z3
    yamaha 650
    pio 97
    canton cd1
    sky+
    6ft screen
    hoping to get 80" pics
    will keep in touch
    not sure how to get pics on though!?!?!?!
    cheers , Mike
