home cinema
Discussion in 'Home Cinema Building DIY' started by lnewey6, Apr 9, 2005.
  1. lnewey6
    lnewey6
    Nov 10, 2003
    196
    derbyshire
    +3
    new home cinema build i have an outbuilding at the moment its used has a junk room the dimensions are height 7foot 3 inchs length 10foot 4inchs width 6foot 7inchs the roof and floor are concrete the proplem is its only one layer of brick i no ill have to soundproof but will i need to build a new wall with insulation i am a bit new to this have got home cinema but i dont like the undedicated cinema room and what sort of projector and screen can i fit in a room that sizecheers
  2. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Hmmm, that's pretty small - and you are going to lose a good half a foot on each wall for studding and insulation (which you will definitely need) which will only leave you with a 6'x9' room. You will need a PJ with a pretty short throw and I would imagine that a 5' screen would just about work, without being too overpowering. Ask around some local builders is my advice - they tell you what can and can't be done. I assume that the building does at least have power?
  3. Motobug
    Motobug
    Jul 7, 2004
    1,098
    +19
    To save some space, you could "Clad" the outside of the building, you would then need much less insulation inside. In terms of the PJ and Screen, you will need a short throw PJ, something like the Z3. As this will be a dedicated room you could make a fixed screen to a size you feel confortable with. With a room of this size, probably best to stick to a 5.1 system.
    Good luck.
  4. lnewey6
    lnewey6
    Nov 10, 2003
    196
    derbyshire
    +3
    i want to extend the building its 2 foot away from the house the proplem is the building is small i can extend about 4foot at the front which will make it 14foot i want to extend the side2 foot which will make it 8foot but i will part cover the kitchen window and the building has a concrete roof please help
  5. mason
    mason
    Dec 17, 2003
    2,114
    Stirling
    +140
    Who needs a kitchen window anyway!!!
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Who needs a kitchen?
    Beer fridge.
    Take-aways.
    Job done...PJ :thumbsup:
