Home Cinema Upgrade
Discussion in 'Blu-ray & DVD Players & Recorders' started by aa_uk, Jul 20, 2003.
  1. aa_uk
    aa_uk
    I'm looking to add a DVD Player to my current system. Budget is aound £600. Which of these three options is best:
    1) Add DVD Player and Subwoofer to current system (Technics Pro-Logic with 6ch Dolby Digital Input, Front: Total - 160W, Centre: 120W, Rear: 60W.
    2) Buy an All-in-One DVD System such as Sony DAVS888 or JVC THA75R
    3) Buy Seperates (if so, what do you recommend to fit within my budget).
    Thanks.
  2. phenom2003
    phenom2003
    Get some separates, Richer sounds are doing the Marantz 5300 reciever and Eltax evolution speakers for £390 which will leave a fair few quid left to spend on stands,interconnects,speaker cable, and the DVD player,etc. Here's the link
    http://www.richersounds.com/index.php?f=system_builder.htm
    P.S This offer is on the System builder part of the website but must be collected instore.
    Rich
