home cinema system
Discussion in 'Home Cinema Buying & Building' started by PAULRYAN52, Oct 11, 2018.
  1. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    Hi, I'm after a surround sound system and I've looked at Soundbars but would prefer proper surround sound, must have wireless rear speakers as I don't want wires all over my bedroom, preferable a wireless sub if possible, budget £700-800
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    'Wireless' Loudspeakers for the most part are Mains powered so whilst you don't then require Loudspeaker cable to the Surrounds you do require a Mains socket close by - not many rooms have Mains sockets where you would want to position a Surround Loudspeaker.
    One option would be to omit Surrounds and concentrate your budget on the Front of the room.
    Joe
  3. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    I've got sockets where they would go
  4. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    if I forget the rears what would you recommend
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    Post up a Layout plan and or some pics of the room - ideally you match your Loudspeakers to the Room.
    As Loudspeakers can tend to live with you for a long time you have to decide if you go for something which is a great match with the current room or something which will work in a different space if you plan to move in the near future.
    Joe
  6. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    ok will do
  7. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    it's not accurate but hopefully it helps [​IMG]
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    Layout - I would go with a 2.0 or 2.1 system.
    Amp - you could either go with a Stereo Amp with Digital Input and use the TV as your HDMI Hub or use an AVR and use that as the HDMI Hub.
    Speakers - tall narrow ‘full range’ floor standing could work or Stand mounted limited range. Bookshelf look like they could be problematic as the asymmetric TV Stand may not have space for a Speaker to the right of the TV.
    TV Stand - do you have a pic with the TV in place?
    Joe
  9. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    sure
  10. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    [​IMG]
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    Bookcase - is not ideal as a Loudspeaker support though if you sit a Bookshelf style Loudspeaker cabinet on some isolation block it ought to work OK. With a bit or rearrangement you should be able to accommodate a Front LR at a suitable height (your seated ear level) on your Bookcase.
    Options I would consider are HiFi Amp (with Digital Input/Sub Out) vs. AVR (assuming long term you feel Surround Sound is important) and then I would consider a 2.0 or 2.1 Speaker system.
    Personally I tend to keep things simple and focus my budget on the basic requirement (the Front sound stage) so a HiFi Amp (with Digital Input) plus a pair of Bookshelf Speakers would work best for me.
    Joe
  12. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    could I place the fr & fl on top of the tv unit with the centre by the tv
  13. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    Front LR - only if you plan to be standing up when listening to Music/viewing the TV :)
    You could aim/angle the speakers downwards but why compromise when you have the option of setting them at the correct height in a straight ahead setup.
    Centre - is not required when your Loudspeakers are grouped so tightly around a TV, often it can cause dialogue to be muddled when it is so close to the Front LR,
    Having a Front LCR setup at different heights is another compromise you don’t require.
    Keep the system simple - work with the space and optimise your spend on just the channels you require in your space.
    Joe
  14. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    so what would you recommend,
  15. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    Amp - we have used the Yamaha A-S501 and A-S301 on a few systems where the TV has been used as the HDMI Hub of a Music/Movies system, A-S501 - Overview - Yamaha - UK and Ireland
    Loudspeakers - ideally you would go have a look/listen to a few options which will sit on a cabinet.
    Joe
  16. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    what about lip sync issues
  17. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    'what about lip sync issues' - if it becomes an issue you can add in a digital delay between the TV and the Amp, we haven't found it to be an issue.
    Joe
  18. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    thanks though the shop where I will purchase from doesn't sell that amp
  19. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    Easy enough for them to get hold of one or possibly suggest an option they do stock.
    Joe
  20. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    is a sub needed
  21. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    Not necessarily - we/I have installed hundreds of HiFi and AV systems over the years which did not use a Sub.
    When working to a budget I would try to put my spend in to as few items as possible - that would not preclude adding a Sub at a later date!
    Joe
  22. PAULRYAN52
    PAULRYAN52
    Dec 23, 2005
    515
    Liverpool
    +7
    ok so if I ggo amp & speakers, how do Ii adjust tv volume
  23. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,939
    The Borders
    +3,332
    The Vol of all Sources is controlled on the Amp - some TV’s will allow you to adjust the signal being sent to the Amp using the TV Remote controller
    Otherwise the TV or Amp Remote May be able to learn commands from another device, you use a Programmabel Remote (Harmony) or you use an App based Remote.
    Failing all of that you juggle remotes :)
    Joe
