Home Cinema system..Which one?
bullington
Just purchased a Vizio 42" LCD HD panel from the US and just recived my Sky HD box. I would like to set up a decent home cinema system that allows to me to listen to both the TV and DVD's thru it. I would prefer to go for a DVD included system but wamt to make sure it is a little fututre proof with the right connections so i don't have to switch remotes, change cables etc etc.
My budget is around £2-400 but am open to suggestions.
THANKS FOR ANY HELP IN ADVANCE!
mitchec1
I'm assuming you have the L42 I would recommend the Panasonic Sc-ht855 round about £255 and if you search through the forums a lot of happy owners and good reviews :thumbsup:
