Home cinema start up
Discussion in 'AV Receivers & Amplifiers' started by m4rkyboy, Apr 24, 2001.
  1. m4rkyboy
    m4rkyboy
    I'm looking to set up a system and I'm not sure what my first step should be. I've been looking at receivers and I like the spec of the Pioneer VSX-909RDS. It seems to be a good receiver, but £830 seems cheap for a THX rated receiver,as all other on the market are £1000 plus.
    Also I'm kinda stumped on speakers, is it best to go for a package or separates?
    My current set up is a Sony KV28FX20U widescreen TV and a Sony DVP-725 DVD player.
    Any pointers would be great. [email protected]
  2. Peter O Sullivan
    Peter O Sullivan
    Have you read the review HCC gave for it, can't really go wrong. I have always agreed with there opinions and am happy with any equipment they recommend (I dont have the 909 though).
    [ 25-04-2001: Message edited by: PeterOS ]
  3. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Are you only after an amplifier/receiver with THX certification? If not, have you considered the Denon 3801, reviewed this month in HCC?
    I say this because I bought a Denon and it is fabulous.
    Mark B
