Home Cinema Speakers What to Buy?
Discussion in 'Home Cinema Speakers' started by DarkManiac7, Jul 12, 2005.
  1. DarkManiac7
    DarkManiac7
    Okay im a complete idiot to most home media speakers the only brands i know of are klipsch,JBL,And BOSE because im more of a computer person...but anyway ive been browsing for some speakers for our new home the dimensions of the room are 16'-2" all around the room the ceiling height is about 8-10ft i dont know if any of this matters but just thought id put it down anyway, but the speakers i was looking at was the Definitive Technology Speakers There is no set budget as of yet however i would like to keep the price at a minimum but i was looking at their towers th3 7000 series i believe..but it doesnt even have to be definitve i was just told they were a very good brand if there are any better please tell me!!
  2. inzaman
    inzaman
    Dec 16, 2002
    7,942
    Derby
    +1,020
    Moved to speakers :)
  3. DFL
    DFL
    Apr 27, 2005
    169
    +5
    Hi there, I'm not an expert by any means, but I'm also in the process of building a homecinema system.
    If you want a 5.1 speaker system for your tv room you might and you're on a budget you should start looking at the all in one systemes, which includes dvd/receiver in 1 plus all 6 speakers. Denon, Phillips and Panasonic are big, reliable names to start with.
    www.homecinemachoice.com has reviews which you can search by topic under homecinema packages.
    If you don't want the dvd player and 5.1 receiver (your amp is 5.1 right?) then almost every speaker company makes a 5.1 range.
    Monitor Audio Bronze B4 AV2, B2 AV series, 800-1000 GBP
    Mordaunt Short,
    Mission 2-3000 GBP
    KEF
    The list is endless. Personally, when I started researching, I used the www I quoted earlier a lot and then asked the forum for info on more specific q's. Sorry never heard of the Towers TH3 7000 series.
  4. BUGANNA
    BUGANNA
    JBL are excellent, built like little tanks, are small, and sound is more than enough quality for cinema setup
    JBL are used in most cinemas, and Disney World too..........
    but they dont look very nice, plain ugly black industrial looking
    i would avoid things like Mission NXT range, they just sound too compressed / shut in.........
    Accoustic Energy, make a brilliant package, full metal drive units, nice looking, and great value
    these are my 2 recommendations -
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  6. DarkManiac7
    DarkManiac7
    Yes, Texas Actually,
    I guess yall dont really like Def Tech then? or are they a good brand but too expensive?
    thanks for the help BTW
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Well the reason I asked was that Def Tech and Klipsch aren't really available in the UK where this site is based so we can't give a very good answer. All of the replies so far have related to UK models.
    As much as we'd love to help you it may be better to field your equipment question to the US forums such as:
    www.avsforum.com
    http://forums.audioholics.com/forums/
    www.hometheaterforum.com
    Those sites have plenty of reviews and information, as does www.hometheaterhifi.com
    once you've got your equipment please come back for further advice or even if you just want an unbiased opinion based on specs. Otherwise it's not really fair for us to comment about equipment we havn't heard and have no idea about price or competition for. :)
  8. DarkManiac7
    DarkManiac7
    ok but are there any speakers from both US and UK that are good?
  9. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    M&K make excellent home cinema speakers that are far more reasonably priced on your side of the pond than in UK.
  10. DarkManiac7
    DarkManiac7
    ill have to look in to them thanks!
  11. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  12. DarkManiac7
    DarkManiac7
    ok i think i found a system i liked
    1 pr Axiom M60Ti Towers
    1 Axiom VP150 Center
    1 pr Axiom QS8 Surrounds
    1 pr FMSQS Stands for QS8s
    Total: $1,952.25 Shipped
    Subwoofer:
    1 PB-12 Plus in black
    Total: $974 Shipped
    Receiver:
    1 Denon AVR-3805 from Crutchfield
    Total: $999.99 Shipped
    Speaker Cable:
    500ft Belden 5000UE 12ga from Westlake Electronic
    5 pk Dayton Banana Plugs (used in article here
    Total: $151.29 Shipped (To Zip 75757)
    Interconnect Cables from Ram Electronics:
    2 2m Toslink Cables (Green) (For X-Box and PS2, assuming you have them)
    1 2m Digital Coax (for DVD Player)
    1 2m 6ch Analog Cable (for SACD playback on Universal player)
    50' of Velcro Cable Tie
    1 2m Component Video Cable for DVD Player
    1 Custom Length Component Video Cable (~30ft, ~$100)
    Total: ~$222.29 Shipped
    Room Treatment:
    DIY acoustical treatment using methods discussed here
    Total: ~$400
    Power Conditoner:
    Tripp-Lite HT10DBS
    Total: $85.83 Shipped from J&R
    Miscellaneous Stuff:
    Radio Shack Analog SPL Meter
    DVE Setup Disc from CD Universe
    Total: $65.07 Shipped
    Grand Total for All Audio Equipment and Cables, Including Shipping): $4850.72
    tell me how you like it!!
  13. hedrick@rutgers
    hedrick@rutgers
    May 9, 2005
    57
    Different makes tend to have different sounds. That's one reason people are reluctant to recommend a specific model. Axiom is well regarded, but not everyone likes them. That's not necessarily a problem. But if you're new to hifi, before spending $2000 on speakers, you really, really need to take a fair amount of time to learn what is available and listen to alternatives. $2000, even for 5 speakers, is a lot of money. In that price range you can get something really good from several different companies. Axiom may be just fine, but I'd rather have you spend time listening to other alternatives.
    If you look at www.avsforums.com in the speaker section, you'll find lots of threads reviewing the major models available in the US in this price range. You'll also find a number of people from Texas, who can suggest where to listen to speakers.
  14. hedrick@rutgers
    hedrick@rutgers
    May 9, 2005
    57
