Home cinema speakers vs Professional speakers
Discussion in 'Home Cinema Speakers' started by snejk, Jul 4, 2005.
  1. snejk
    snejk
    Home pages of most speaker brands allow you to choose between 2 categories:
    Home cinema / audio OR professional.
    What exactely is the difference between the two?
    From the products in both categories i got the impression that PRO is used more for outdoor installations and some are very powerful and are much bigger. But as regards to sound quality ???
    If you are more into music does it make sense to install "small" Pro speakers in your listening room ??
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,130
    Rainham Essex
    +2,392
    It depends on how you define a Pro speaker. PA speakers are normally big and powerful, but wont have such a good sound quality. Then you have the nearfield monitors (eg my speakers, see sig below post) that are small and normally of very high quality.
    Pro nearfield monitors are often made without speaker grills and the case is not made with the same TLC you would get from HiFi/AV speakers, and therefore have far less WAF!
    Mark.
  3. davehk
    davehk
    Oct 17, 2003
    702
    28
    London
    +45
    And if you ask a pro audio engineer about the difference between domestic hi-fi speakers and pro near/mid field monitors, they will tell you that hi-fi speakers are designed to sound good (ie they are coloured), whereas pro monitors are designed to be accurate so that the mix engineer can hear what is really in the recording.
